12-14-2011 03:28 PM
I would like to overlay a dial on top of an image in LabVIEW. It would be great if the dial could rotate about the center axis. I included an attachment of what It would possibly look like. Please let me know if any of you know how to do this.
Thank you!
Solved! Go to Solution.
12-14-2011 03:57 PM
You should use the Picture object for this. It has a slew of VIs to draw all kinds of things. Combined with the geometry VIs, you should be able to achieve what you want quite easily.
12-14-2011 04:12 PM
This tutorial might help you: https://decibel.ni.com/content/docs/DOC-4819
12-14-2011 04:13 PM - edited 12-14-2011 04:14 PM
You need to set the other items on a normal dial to transparent and place it on top the image.
12-16-2011 12:15 PM
THANK YOU!!!
12-16-2011 12:19 PM
Would you be able to save down to LV 9?
12-16-2011 12:37 PM
2009
12-16-2011 09:00 PM
12-19-2011 05:39 PM
I apparently misinterpreted the question...
In any case, I am attaching an example of what I had in mind (LV 2011 project), for what it's worth.
12-19-2011 06:31 PM
LV 2009 version.
