Can LabVIEW FPGA IP Export support Zynq UltraScale+ MPSoC?
I am really interesting to use my mathematic algorithms from my old Zynq-7020 SoC based sbRIO in a new Xilinx Zynq UltraScale+ MPSoC. Is it possible to generate VHDL for Zynq UltraScale+ targets via LabVIEW FPGA IP Export Utility?
(2,574 Views)
The documentation says the FPGA must be from the same family.  That said I have seen this get stretched if the functions being used are not too specific.
ALE Consultants
(2,565 Views)
I am using High Throughput Math Functions for example: Complex MultiplyRectangular to PolarSquare RootMultiply, Add for 16 bits fixed-point datas/numbers and some z^-k delay boxes. Aren't these too specific yet?
(2,549 Views)
@sz.benjamin wrote:
I am using High Throughput Math Functions for example: Complex MultiplyRectangular to PolarSquare RootMultiply, Add for 16 bits fixed point numbers and some z^-k delay boxes. Aren't these too specific yet?
Maybe try a proof of concept using the evaluation mode of this add-on.  Make a VI with just one of these functions and see how it exports and can then be imported.  Do you have VHDL/Vivado expertise?
ALE Consultants
(2,542 Views)
I have strong experiences in Vivado block design making and using them on AXI bus with Linux kernel drivers, but i have much less in VHDL coding.
(2,540 Views)
Then definitely worth a shot.
ALE Consultants
(2,514 Views)
