If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
‎04-26-2011 08:13 PM
I want to use a WindowsCE based touch panel to control my system by connecting a CompactDAQ to it through USB and installing the.exe file built from LabVIEW and installing the CompactDAQ drivers.
It sounds doable, but I don't know if WindowsCE does support those .exe files or the hardware drivers or if there is something I can do to make it support them. I hope anyone has an idea about this and can help me.
Thank you
‎04-27-2011 01:14 PM
Mr. Who,
You should be able to do this, however, the version of Windows CE that you are running will determine whether or not it is supported by NI. What versions of Windows CE and LabVIEW are you running?
‎04-27-2011
01:23 PM
- last edited on
‎03-14-2024
09:07 PM
by
Content Cleaner
Please note that you would also need to purchase a LabVIEW Touch Panel deployment license as well. Please refer to the links below for more information:
‎04-27-2011 01:47 PM
‎04-27-2011
02:40 PM
- last edited on
‎03-14-2024
09:08 PM
by
Content Cleaner
I found the following statement at :
LabVIEW Touch Panel Module Getting Started Guide
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5HUCAY&l=en-US
"The deployment procedures discussed previously for NI touch panels are not guaranteed to work for third party touch panels. If the use of a third-party touch panel is desired it must met certain requirements in order for the LabVIEW touch panel module to properly work with it.
The LabVIEW Touch Panel module only officially supports the two operating systems and two processors that the NI touch panel devices are based on. The operating systems supported are Windows CE 4.2/5.0 and Windows XP Embedded, while the supported processors include the StrongARM, XScale, and x86.
Another consideration when using a third-party touch panel is that a LabVIEW Touch Panel Deployment License must be purchased for each deployment of an application developed with the LabVIEW Touch Panel module.
In addition, specific Microsoft tools must be installed on the touch panel target in order for the LabVIEW Touch Panel application to function as expected. The following Microsoft eMbedded Visual Tools need to be installed:
‎04-27-2011 06:44 PM
Thank you for your help, but there is still the same question, can I use this touch panel to control the system as same as the industrial controller? can I install the .exe file and connect a ConpactDAQ to it through USB?
‎04-28-2011
12:40 PM
- last edited on
‎03-14-2024
09:09 PM
by
Content Cleaner
Mr. Who,
In reviewing the latest driver readme for DAQmx base (required for Windows CE devices) I found that cDAQ chassis are not supported by the driver. You can use some individual cDAQ modules with a USB sleeve and some other multifunction USB devices, but you cannot connect a cDAQ chassis (with modules installed) to a touch panel.
‎04-28-2011 12:44 PM
Well, we've decided to use NI Industrial Controller instead, I guess, if I didn't miss understood, it works as a normal PC so that I can connect my cDAQ to it and install my drivers and application as any normal PC. Right?
‎04-28-2011
01:14 PM
- last edited on
‎03-14-2024
09:10 PM
by
Content Cleaner
Hey MrWho,
That is correct, assuming you are referring to these models:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/206844
They run windows XP and will be functionally the same as running DAQmx on your own PC. One thing to consider is that, if you assigned custom names to your hardware, you will need to transfer those names over for the application to function as expected.
You can also do this programmatically using the system configuration API: https://www.ni.com/en/support/downloads/drivers/download.system-configuration.html
‎04-28-2011 06:21 PM
Thank you so much, that was very helpful 🙂
