10-25-2001 11:53 AM
10-25-2001 04:26 PM
10-26-2001 02:36 AM
10-26-2001 07:05 PM
06-16-2006 10:56 AM
I’m writing you concerning your NI post on using “Out Port.vi” to write to the parallel port, you seem to be very knowledgeable on the subject and I’m hoping you can help me out. I’ve been having a heck of a time trying to write values. I downloaded your VI for Labview 6 (I have 6i) and am using Out Port.vi. The computer tells me the port address is 0378-037F yet when I put this address (378,379,etc) as input to the VI and change the value between 0 and 1 (I assume that is low/high, but I’ve tried larger numbers also) I get no change. I looked at a bunch of post and one NI told me to install the 5.5 CVI runtime engine, which I did, but still nothing. I downloaded a separate monitoring/writing program to see if my port is broken but that program toggles the values just fine. I’m really at a loss, is there something other than the simple out port.vi I need to use?
I’m running XP pro.
Thank you for your help,
James
06-18-2006 09:35 PM
