By default, the stl texture is off. You can enable texture by using this property.
Now, you also need to set horizontal and vertical wrapping mode for the decal to apply. Below I have Repeating and Linear and Spherical. It does apply the texture, but there is some work to map to the polygons.
Barp - Control, Simulation, RTT and HIL - National Instruments
