Can I use a DAQCard-6533 with LabVIEW 7.1?
I would like to use a DAQCard-6533 with LabVIEW 7.1. I want to use it in my iPAQ 2210 and also in my laptop with Windows XP. Is this possible?
Many thanks,
Max
(3,233 Views)
Max,
Greeting.
Yes, you can use your DAQCard-6533 with LabVIEW 7.1. You also want to make sure you are using the right driver. You can find the most recent drivers here:
http://www.ni.com/support/daq/versions.htm
Additionally, that card will work great in your laptop with the normal NI-DAQ driver. However, it is not currently supported for PocketPC. The PocketPC requires use of the NI-DAQmx Base Driver. Here are the list of devices currently supported by the DAQmx Base 1.0 for PocketPC:
NI DAQCard-6024E 200 kS/s, 12-bit, 16 AI channel, two AO channel, eight DIO line, two counter/timer device
NI DAQCard-6036E 200 kS/s, 16-bit, 16 AI channel, two AO channel, eight DIO-line, two counter/timer device
NI DAQCard-6062E 500 kS/s, 12-bit, 16 AI cha
nnel device
NI-DAQCard AI-16E-4 (6041E) 500 kS/s, 12-bit, 16 AI channels, eight DIO lines, two counter/timer device
Anuj D.
(3,233 Views)
