Can I upload an applicatioin to the Real Time system and run it?
Hi, I'd like to take advantage of some tools in the real time system.
I thought I could upload it by file-transfer,
and then did something like this in the real time system.
No doubt it is failed...
Nonetheless, is there other ways to realize my thought in the real time system?
Message 1 of 11
(4,768 Views)
I don't know about cRIO, but on my PXI system, the app has to be *.RTEXE, and it has to be built with LabVIEW.
Simply moving a generic EXE over there will not work.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 2 of 11
(4,751 Views)
Was the EXE compiled to run on an ARM?  I'm guessing no which might be one of your problems.  I know NI had some kind of package repo but honestly I haven't even used this hardware yet (but would love to).  But with the new cRIOs running Linux you can use the system exec on the RT target to run applications.  You can also use the call library node somehow but not on DLLs that's a Windows thing.
Message 3 of 11
(4,744 Views)
Hi, CoastalMainBird,
Thanks to your reply, but what I want to implement is something like "iperf.exe", or "ipconfig.exe",
Is it impossible to call the other exe(third-party?) in the real time system?
Message 4 of 11
(4,725 Views)
Hi Hooovahh,
Thanks to your suggestion.
Yes, I've read the article that System Exec.vi can be used in RT Linux system, but what about not that kind of real time system?
In fact, all I know the system in my CompactRIO is real time sytem, I do not know how to distinguish Linux-based or not.
However, I can not use System Exec.vi, so mine is probably not Linux-based real time system.
How can I do the function such as System Exec.vi in this kind of system?
I'm not sure what you mean "but no on DLLs", if I use the Call Library Node, What should I call??
Message 5 of 11
(4,723 Views)
Run MAX on your host, and select the target.  Look in the SYSTEM SETTINGS area for OPERATING SYSTEM. RTOS.PNG
Steve Bird
Culverson.com
LinkedIn
Message 6 of 11
(4,718 Views)
Not if the program was not compiled for that OS.  Windows programs assume a WIndows environment, and will fail if it's not there.  The same applies to other programs and other OSes.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 11
(4,715 Views)
Thank you for the direction:)
Now I know how to determine the OS system~~~
Message 8 of 11
(4,701 Views)
Do you mean the exe was built for windows, so that it is not allowed to execute in real time system? If it is true, I'll suffer a lot because I have to communicate between CompactRIO and servers by ethernet cable...
Message 9 of 11
(4,698 Views)
Accepted by topic author William1225
Correct.
so... you write a program to run on the cRIO, and have it talk to your server(s) via TCP.
Steve Bird
Culverson.com
LinkedIn
Message 10 of 11
(4,687 Views)
