06-05-2006 05:13 AM
06-05-2006 06:00 AM
It's not a bug. The event structure registers for the events when you run the VI. The event is set by default to lock the FP until the event completes, so at the moment LV recognizes the event it locks the FP and the clicks on the other stop button won't be processed until the event case completes.
You could ask whether LV should lock the FP when the event occurs or only when it actually starts running the event case, but I assume there is a good reason for how it works now. I understand this is just an example, but in general, you should not place UI handling code in different sections of your code (and definitely not in places which affect each other as the different frames of a sequence structure). If you do have problems for some reason, you can set the event not to lock the FP when you define it.
06-07-2006 09:05 PM
06-07-2006 11:30 PM - edited 06-07-2006 11:30 PM
Message Edited by altenbach on 06-07-2006 09:31 PM
06-07-2006 11:45 PM
06-08-2006 01:19 AM - edited 06-08-2006 01:19 AM
@Gilbert-Lin wrote:
if I have to use Sequence struture and the other structure needs event case, what the program component be well ? must set the event case at the first occur status(field) ?
A typical mistake of beginners is overuse of sequence structures. They are rarely needed! (some seasoned LabVIEW programmers consider stacked sequences evil). I haven't used a stacked sequence in years. In the rare cases where dataflow need some guidance, a single-frame flat sequence structure will often do the trick. 🙂
Have a look at e.g. a state machine architecture. 🙂
What kind of program do you have in mind?
Message Edited by altenbach on 06-07-2006 11:22 PM
06-08-2006 01:41 AM
altentach, thanks your help !
-________________________________________
__________________________________________
en, a word can't tell details, let me have a good think, take your words "rethink" the program would be better. .
