Can I replace "AI Waveform (scaled array)" with a newer subroutine?
I'm dealing with a program that references AI Waveform scaled array, which I understand is a Labview 6 vi which can be supported by installing older drivers. My question is, is there an updated version of this function in 2009 that I can swap out and completely stop depending on this older scaled array function?
Thanks in advance,
Justin
(3,206 Views)
If your DAQ card is supported, you can start using the DAQmx functions. This will require a complete rewrite since the DAQmx functions are not a one - to one replacement.
(3,193 Views)
I guess more specifically, is there an equivalent subroutine that would offer the same functionality as this older scaled array waveform function?
(3,171 Views)
DAQmx Read.
(3,164 Views)
