Can I regulate my x-/y-scale on Waveform Graph?
In my program I indicate several signals successively with different frequences. I managed it with a case-structure. Can I give the WaveformGraph scales, automatically the associated attitude.
I won't set the scale always manual.
(2,745 Views)
you can use a attribute knode for this job.
Niko
(2,745 Views)
You can use the Y and X scale range property in a property node to set these properties programmatically.
Take a look at the following screenshot.
(2,745 Views)
