Can I lift one of the RS232 pins for two seconds? how? (I'm working with labview)
help
(2,965 Views)
First you have to open VISA serial session using "Visa Configure Serial Port.vi" (Instrument I/O / Serial). Then you have to use "Property Node.vi" and choose in pop up menu such property as "Modem line settings". These properties allows you to control 6 modem lines.
Oleg Chutko.
(2,965 Views)
I you are using the standard RS-232 functions, use "serial line ctrl.vi". This function is in
...vi.lib\platform\_sersup.llb. It allows you to control the state of DTR and RTS.
(2,965 Views)
