Can I interface Mathcad 12 and labVIEW 6.1 using the mathcad script wizard
I have an application using Mathcad 12 and LabVIEW 6.1. I am working with a PCI 6031E and running Windows 2000.
I would like to interface this Matchcad application with labVIEW 6.1 using the "mathcad script wizard"
Is this possible without redeveloping the software, do I need to upgrade labVIEW to make this work.
Any help would be greatly appreciated.
Andrew.
(2,809 Views)
Hi Andrew,
It looks like there is some functionality with this, but we are not extremely experienced with it.
The one thing I've found for use with LabVIEW 6.1 is here:
ftp://ftp.ni.com/contrib/epd/B45EACE3F18856A4E034080020E74861/LabVIEW_and_Mathcad.zip
(Using LabVIEW With Mathcad in a Design Application -- It came along with a tutorial that is no longer online)
Searching our Developer Zone, I also found some Mathcad Interface VIs, but unfortunately, they were written for LabVIEW 7 and greater.  I would recommend updating LabVIEW so that you can work with these interface VIs:
ftp://ftp.ni.com/contrib/epd/C21DD1348D8C5681E034080020E74861/Mathcad.zip
ftp://ftp.ni.com/contrib/epd/C21DD1348D8B5681E034080020E74861/README.txt
Thanks and good luck,
mike
(2,797 Views)
