Can I get MJD (date and time) in LabVIEW 2012 SP1?
I need to time stamp my data before sending it to the file.  I have been doing this with the standard calendar date and time but MJD is what we prefer to use.  How can I get an MJD timestamp in LabVIEW 2012 SP1?
(4,463 Views)
Did you check this http://www.ni.com/example/26818/en/ ??
uday
(4,449 Views)
Hello Brad_Henry,
The Format Date/Time String will return the day of the year when the %j argument is used, as per this help document:
LabVIEW Help: Format Codes for the Time Format String
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/string/format-codes-for-the-time-fo...
If you're looking for the actual MJD, I'm not aware of a built-in function that generates this so you'll probably need to create or find a function to calculate it manually.  This should pretty basic arithmetic, and it looks like people have already made a few public examples, the first two search results here look to be just about what you need:
ni.com search:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:ex/q/julian/
Tom L.
(4,442 Views)
Thank you but that does not give MJD, it gives JD.
Brad
(4,441 Views)
Accepted by Brad_Henry
Check the formula for converting JD to MJD
http://www.iers.org/nn_10828/IERS/EN/Service/Glossary/mjd.html
The Modified Julian Day (MJD) is defined as MJD = JD - 2400000.5 , where JD is the Julian Day
uday
(4,434 Views)
