For some reason, these VIs don't accept strings as input. If you double click them and look at their block diagram, you will see instructions for modifying them. If you do, you will have to convert your numbers to strings and then back to numbers when you read from the file. Also, make sure you do not overwrite the original file.
___________________
Try to take over the world!
