08-17-2011 01:26 AM
Dear sir my problem is that -
I create a VI and published in local server and it works properly, and I give a hyperlink on my front panel that will launch a separate web browser on server system (in HTML format) when I click that is working properly.but when I published that VI in web server and any client / user open my vi so that HTML file open in server system not in client / user system so please help me for solve this problem as soon as posiable..
08-17-2011 02:48 AM
Hi Neeraj,
As you mention your application is working fine on localhost but if you publish it on server its not working. Whenever any client open your web page open on server side.
I hope first you check web server is enable or not on your server.(tools-options-web server) check the port for your web application.
To publish your application on web you use web publishing tool(tool-web publishing tool) Select your VI and configure it as a web application.
If you are publishing on web the Public IP should be available on your server.
Now check your URL is working fine on server system & your URL is in this http://serverIP:port/applicationname.html format.
If your application is working fine on server then you try on other PC.
Thanks and Regards
Himanshu Goyal
08-17-2011 03:08 AM
Dear Himanshu,
These all steps we taken for web publishing (my vi already publish in public IP) but my concern is that i want to add Hyperlink for client side in remote panel and as usually we added but the Hyperlink of new HTML open in new browser on server site. So please give me some solution for this problem.
