03-20-2014 10:22 AM
I have a Thorlabs USB camera (DCC1645C). I have installed the drivers, and MAX is detecting the camera but when I try to open the camera with NI-IMAQdx, it doesnt appear. I have also tried to open the camera with NI-IMAQ but I wasn't able.
If I try with Vision Express/Vision adquisition, the camera is displayed, I am able to select it and configure the camera adquisition, but when I execute the program there an error: "camera not found".
It would be great some help.
Thank you
Solved! Go to Solution.
03-20-2014 11:20 PM
What is your LabVIEW version, your Vision software versions and iMAQdx version?
Since Thorlabs is using USB 2.0, you can read about the USB 2.0 section of this link: http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
Check if you have the required iMAQdx driver and its compatibility with your other NI softwares:
http://digital.ni.com/public.nsf/allkb/DB928F6D5E9D6B97862579A7006B2850
http://digital.ni.com/public.nsf/allkb/4A127014CA6E006B8625787A0066D329
http://digital.ni.com/public.nsf/allkb/244E6DDF9A92A6CD8625730100629047
NI IMAQ for USB Cameras:
http://www.ni.com/example/30030/en/
Warmest regards,
Lennard.C
03-21-2014 02:14 PM
I have:
LabVIEW 2013 (64-bit)
NI-IMAQdx 4.3
NI Vision 2013
The camera is detected by MAX and displayed as a NI-IMAQdx device. Im able to grab images from MAX with the camera. But Im not able to select the camera in Labview. It could be some problem related with the 64-bit version of Labview? In this case, there is any solution?
Thank you.
03-21-2014 05:44 PM
@AurelioSilva wrote:
I have:
NI-IMAQdx 4.3
NI Vision 2013
Thank you.
dear
donot use NI-IMAQdx
use NI iMAQ deriver
03-21-2014 11:59 PM
It is posible to use NI-IMAQ driver with a Thorlabs USB camera? I though that for USB camera the IMAQdx was the only option.
03-23-2014 10:31 AM - edited 03-23-2014 10:34 AM
Hi AurelioSilva,
Actually, NI IMAQ driver is used for NI Hardware only. For 3rd party hardware (like your USB camera), I would recommend the use of iMAQdx. You can find the difference between the iMAQ and iMAQdx here: http://digital.ni.com/public.nsf/allkb/0564022DAFF513D2862579490057D42E
Now back to your problem. When you mention LabVIEW 2013 (64bit), I believe that might be the issue. You see, most of the drivers like iMAQdx and iMAQ are supported by LabVIEW 2013 (32 bit) only. Don't worry, you can install and run LabVIEW 2013 32 bit in your 64 bit OS computer cause I'm doing that all the time with 3rd party cameras. In short, not all NI drivers are supports 64 bit version of LabVIEW. You can read about it here: http://digital.ni.com/public.nsf/allkb/E9B4EA0143514DCB8625725D0050680A
Warmest regards,
Lennard.C
