Camera configuration FlexRIO 7975R & 1483 module
Hi, I'm new user of Labview. I'm working with a Flex RIO card, the PXie 7975R and the adapter module NI 1483. I have a Sensor Unlimited (GL2048L) line scan camera plug on the NI 1483.
Form my understanding, when using a FlexRio card, I have to VI (on the host or the FPGA) to configurethe settings of my camera. The 1-Tap 10bits from the NI example provide a Serial Server to communicate with the camera. I designed A TCP client to be able to talk to my camera from the host. I'm able to send the command I want but I'm not receving anything from my camera. I tested the camera and It's working fine.  Here are the command I'm sending which are simple: (http://wasatchdevices.com/cobra-camera-link-commands/#20)
init
lsc 0
gain 100
offset 0
int 90
ltm 100
lsc 1
The VIs using are attached. (Test_serial NI1483 is the Host) .  TCP server and TCP client  are working together.
Is there anything I'm soing wrong?
Can someone explain me how the Serial Server vi provided in the 1 Tap 10 bits example works?
Thank you for your help!
(3,049 Views)
Hi Mikeki,
I have a few questions after reading your post.
1. You said you tested the camera, how did you go about testing it?
2. Do you have a real-time or Windows OS controller for this PXIe chassis?
3. Have you made any changes to the 1 Tap 10 bit example? If so what are they?
4. For my own curiousity. Why did you choose the FlexRIO as the hardware necessary for this project?
Aaron F.
Applications Engineering
(2,967 Views)
