Calling several instances of a DLL
We develop a LabVIEW application which call a DLL. This DLL calls a lower lever DLL for communication with a device (but that's transparent for LabVIEW), and it works fine:
We would need to support several devices at the same time:
Unfortunately, this dll can only manage 1 hardware device.
How can we call several instances of a dll? I think each instance of the dll has to run in a different thread.
I've been told a solution to copy several times the MediumLevel dll file and rename each one? It might not work as it would probably call the same LowLevel dll.
Is there a better solution?
Message 1 of 13
(315 Views)
Accepted by Romain.P
Two possibilities
1) Renaming the DLLs as many times as you need a device and then create seperate VIs for each of them.
2) Remoting the DLLs in a separate process each and talk with them over IPC such as TCP/IP or VI Server.
Option 1) may catastrophically fail if the underlying DLL follows a similar stupid one session API design or has some other concurrent call trouble such as not being multithreading safe.
An additional action you might consider:
3) Whacking the developer on his head for only providing a trivial one session API instead of a truly session based API with an Open that returns a session handle and the Read, Write, Close and whatever taking that session handle to work on a specific device.
Rolf Kalbermatter
Averna BV
Message 2 of 13
(268 Views)
Thank you for you feedback.
1) I can rename the MediumLevel dll and call it, but if I also rename LowLevel dll, I think it won't be find anymore by the MediumLevel dll...
2) Do I have to create an executable per thread I want?
Message 3 of 13
(242 Views)
The options are:
(1 and 3) OR (2 and 3)
3 is mandatory 😉.
See for instance: c++ - Load the same dll multiple times - Stack Overflow (esp. notice "I echo the comments above that encourage you to re-design the system architecture.".
Renaming the MediumLevel.dll wouldn't help. You'd still get one instance of the LowLevel.dll.
Message 4 of 13
(235 Views)
Wiebe already told you more or less the options. If the LowLevel DLL was programmed smart and uses a session based API, and the high level DLL is just a wrapper for noobs who can't be bothered with sessions, it would work. If the LowLevel DLL is the main reason for this session-less API, then the only option is to create a new process for each device and yes that means one LabVIEW executable per process and some Interprocess Communication (IPC) with them from your main app.
I would contact the developer first, maybe his low level DLL is all that you would need to access and he might be willing to provide the documentation for its API. Maybe not, but as we keep saying, you can get a yes only if you ask, a no you have automatically if you don't ask.
Rolf Kalbermatter
Averna BV
Message 5 of 13
(226 Views)
Personally, I'd be really tempted to pull MediumLevel DLL into your LabVIEW Code - then you can manage the calls to LowLevel dll much easier in the long run as you have full control over the interface and MediumLevel DLL breaking can't break your LabVIEW APP.
putting the MediumLevel DLL into your own personal comms module is a PITA, but it's something I've done on more than one occasion when the LowLevel dll was not hackable/ editable / changable. (Then you can call  LowLevel dll by path) and spawn as many instances at runtime as you need from 1 module that you maintain.)
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 6 of 13
(215 Views)
I'm going to jump into this.
You are asking the wrong question!  Your question should be reworded as:
"How can I communicate with multiple devices of the same type?"
You should include information about how the device communicates.  You may include the statement that "Some Other Idiot" (SOI) has failed to provide a suitable API and you need to program a new driver in spite of SOI's poor effort.
And you must take the required action 3.
"Should be" isn't "Is" -Jay
Message 7 of 13
(209 Views)
Whilst I too wholeheartedly endorse action 3, I have never been able to do it as SOI has always been my superior or client, hence my proposed solution of reducing the ability of SOI to screw things with 2 dlls instead of 1!
It maybe that the OP is in the same situation as I have found myself in the past.
James
Message 8 of 13
(202 Views)
James
I've always found that the only difference between "Spaghetti Code" and code that is "Richly Featured" is one was written by my boss.
Message 9 of 13
(190 Views)
I agree. If a programmer fails to see that an interface to 1 device would benefit from an interface to n devices, I'd seriously doubt the quality of everything else from that source.
If I could reasonably make a pure LV driver in a few days, I'd do that and be over with the dll.
Message 10 of 13
(162 Views)
