Call Library Node on NI Linux RT OS (cRIO-9039) from Windows LabView
I am trying to call external libraries from my cRIO on Labview.
The libraries are compiled directly into the cRIO. There are located in some folders that are well included in the ldconfig. With a Linux executable, I tried to call these libraries directly on the cRIO. It works well.
Now, I want to move to LabView (on my x64 Windows machine). I used the call library node blocks where I specify the location path of the library with the selected functions.
But it seems strange since the program tries to work on the Windows machine with Windows path and .dll library extension (that I don't have, only lib*.so extension).
For the bath, I fixed the problem with "Build Path" blocks. But for the libraries, I don't know. I am sure that it is possible to work with .so library on Windows machine without the corresponding .dll library, no ?
Thanks for your help,
Message 1 of 1
(940 Views)
