Calibration of PCI-6704?
I'am a starter in Labview and have the following problem: We have a test equipment with a PCI-6704 AO-Card. When I want to give an output signal of 10V with Max to the two used analog outputs, I get 10.5 Volts output. I think the card has to be calibrated. I already found a procedure for calibration the card with a VI.  My problem is, that on the testing computer is just the runtime installed, no Labview. On another computer I habe a labview licence, but this machine doesn't support large PCI-cards. Is there somewhere a complete exe-file for calibrating the 6704-card in the testing computer? Or does somebody know another solution for this problem?
Many thanks in advance
Heiko
Message 1 of 1
(1,751 Views)
