Calculating Odd CRC
I think I have discovered the issue, If I rearrange the byte order; F1 = 1F, use the last 3 bytes of data, this thing works.
Message 11 of 18
(2,618 Views)
Ok, Magic.  Or maybe Voodoo.
BS
Message 12 of 18
(2,614 Views)
That would be swapping nibbles, which is a bit weird. In hex, F1 is a single byte.
Note that in the C code, the second and third byte are the message length, but they are also part of the CRC. The Delphi example, on which you seem to have based your LabVIEW code, has a fixed Count of 3, but the sample messages you provided actually have a length of 6 (thus the "00 06" in the second and third positions) - although, oddly, that length appears to include the CRC byte. Alternatively, following the comments in the Delphi code, it's hard-coded for mode 1 (starts with FE) but your messages are mode 3 (starts with F1, contains 5 bytes without the CRC).
Message 13 of 18
(2,609 Views)
Swapping nibbles seems to be a fluke that just happens to work with the mode commands only
Message 14 of 18
(2,596 Views)
Accepted by topic author MikeMack747
Here's a direct translation of the C code into LabVIEW, as a snippet:
Message 15 of 18
(2,585 Views)
The Exclusive Or seems to have the same results as ANDing with with x80.
Thanks and kudos to nathand for solving this for me!
Many thanks
Mike
Message 16 of 18
(2,568 Views)
My mistake, shifting a right 7 has the same effect as ANDing with 80h
Message 17 of 18
(2,555 Views)
Only when followed by a comparison with 0. When combined with that comparison, they both check if the highest bit in a byte is set. In one case you are ANDing with a value that has only the high bit set; in the other case, you are shifting the highest bit to the lowest and replacing all the higher bits with 0.
Message 18 of 18
(2,535 Views)
