Calculate output value with Custom Scale
Highlighted
I have defined some custom scale in MAX.
I just want to calculate the output value of an input value applied with these scale.
Process is simple :
X =>    Custom Scale  => Output Value
in            Process               out
Is there a way to do it simply (recall : custom scale can be linear, polygon, table etc ...) ?
(1,252 Views)
Hello Educhene1,
You can use easily with labview your scale created previously in Max.
You just have to drag your scale into a labview VI (diagram). Next to it, you can create a property node, select the "activescale" as a standart and create just below one intput in writing and one output (reading).
I'm adding you this link ( http://www.ni.com/example/26625/en/) which just describe what you are looking for, just in case.
Best regards.
P.Denis
(1,208 Views)
Well, in fact, now I have no scale defined in MAX.
I have a table with X and Y values like :
X                Y
1,0             2,0
2,0             4,0
5,0             6,0
and I want to know the Y value of the X value 3,0 for example (using this table scale).
Do you know how to do it simply ?
(1,111 Views)
Accepted by topic author educhene1
Looks like you might need to check interpolation
http://zone.ni.com/reference/en-XX/help/371361J-01/gmath/interpolate_1d/
uday
(1,081 Views)
