CPU Load at RT Loop varies every time
Highlighted
I have a simple CAN Read Node in a RT Loop which runs on an sbRIO.
The CPU Load is at about 5-10%.
When I stop the VI and start it again, it sometimes goes up to 90% on one core.
Has anyone ever had such a problem?
(600 Views)
Highlighted
you have to put a sleep (with for example 250ms) somewhere into the while loop, please take a look into the attached image.
(546 Views)
Highlighted
Hi Kevin,
This is a Timed Loop. The delay is set in the loop Settings.
(532 Views)
Highlighted
Although this is a timed loop, I think you need to sleep for a while.
I can't explain why, but for me it mostly fixes this problem
(501 Views)
Highlighted
Hi nicolaus33,
are you still struggling with this issue?
If so, could you please write a little bit more about your project or perhaps share it? What is the part number of your sbRIO? Why are you using 1 MHz timed loop to read data from CAN? What does your application in general and what does this loop do in the context of whole project?
(449 Views)
Highlighted
Hi Agnes,
I get CAN Messages down to every 8ms and because you can only read one message at a time with the sbRIO CAN function, I need to use this fast cycle time.
(394 Views)
