03-26-2010 08:51 AM
Ben wrote:And now that you have all agreed with answer "c" think about what the answer is if we have Iteration Parallelism enabled where the order of each iteration is not guarenteed. If you put an indicator on the FP of a loop run parallel, then "i" terminal will flash the interations in random order.
If you have not passed the CLAd yet, forget everything I said.
Ben
There comes the third dimension ive been waiting for.
And seriuosly put a disclamer in the thread subject saying please dont go through this thread before your exams.
03-26-2010 08:57 AM
I think NI is just using the "start counting at 0" concept. Another thing that is tested on the exam is that Arrays start at 0 , so the first element in the Array is in position 0, Element 5 is in position 4
Alan
CLAD
03-26-2010 09:54 AM
ThHagel wrote:Hello Denis,
your right!
The iteration terminal will return 0, because for the moment it returns that value the loop has been never executed before. This is what the iteration terminal tells you right at the beginning of your first and only loop iteration: "this loop has been executed 0 times before" (answer a).
hmm. I'm sorry. From my point of view, your example supports my opinion.
Now I don't want anybody to be upset about me being so insistent.
Trust me, I really know how the iteration terminal works. It's not about it's functionality in general, it's more about that stupid question that probably leads to multiple possible answers. I always try to read and understand such exam question as precise as possible and with this one I got into that problem.
I hope that question will not appear in the real exam, because I will mark a as the correct answer. Even if I know they want to here c.
Thanks to all of you for your posts!
Thomas
Your arguement just makes no sense to me. Sorry, but you are overthinking this way too much. It does not return 0 because the loop has not executed before. It returns 0 because the count starts at 0 and not at 1.
03-26-2010 10:09 AM
... Here is my last try ( I promise 🙂 to explain my point of view. Please check out the attached vi.
Greetings and thanks,
Thomas
03-26-2010 10:11 AM
03-26-2010 10:15 AM
03-26-2010 10:42 AM
0,1, 2, etc.
03-26-2010 10:59 AM
Many of these CLAD complaints are certainly valid but you have to remember that NI has to create dozens of versions of a test that covers essentially the same basic material. It would be too easy to cheat if there were only a couple variations of the test. In their effort to word essentially the same question in different ways they almost seem to be purposefully obfuscating the question but I don't think that is their intent.
As others have mentioned, you need to provide the expected answer, even if it seems somewhat illogical to you.
03-26-2010 11:26 AM
Hi Dennis,
I placed some questions on the LastTry.vi frontpanel.
My plan was to make my point of view clear by making you answer them (I expected this to be the ultimate way to reach my target).
It's kind of funny that I again achieved the opposite.
I really appreciate your patience. So if you have some left, please try to answer those questions on the vi's frontpanel.
OK. This is not a very serious subject to me (I'm sure I will not fail the exam, even if I'm wrong here). I was just curious about your opinions.
Have a nice weekend,
Thomas
03-26-2010 11:27 AM - edited 03-26-2010 11:30 AM
Ok. So READ the test instructions. They do not say "Select only correct statements", instead they say "select the most correct Answer" C is the most correct answer as it most closely meet observable model of operation. but suffers from flaws.
