01-24-2006 08:43 AM
Even bad interfaces once they become the de facto standard should not be changed for this reason. The "qwerty" is an excellent example. This interface was chosen to REDUCE productivity, in the original typewriter (I know there are a few in this forum which dont know what a typewriter is, yes they did exist) an alphabetic keyboard was used and the mechanical keys would stick or jam when typed too quickly. This is nolonger the case but different style interfaces have not thrived because it would take to long to retrain everyone. It is odd that UI improvements dont always improve things so NI should give the user an easy switch most likely during the installation on the interface that we prefer to use.
Paul
01-24-2006 10:05 AM
Some people claim that the Dvorak layout, other than being faster to work with, is also more healthy to you because it puts less strain on the ligaments in your hand. I never actually tried it, because I don't do too much typing, and it would probably require putting some stickers on my keyboard to get used to it, but maybe I will try it. I know there are some drivers which allow you to change the layout programmatically.
This would probably be a problem over time. If you have to maintain the interface options you had 4 versions ago just because some users got used to it it would add a lot of overhead to your development process.
@falkpl wrote:NI should give the user an easy switch most likely during the installation on the interface that we prefer to use.
01-24-2006 11:41 AM
01-24-2006 12:00 PM
01-24-2006 12:51 PM
01-24-2006 12:59 PM
Here is a link to the world's fastest typist. 150 wpm for 50 minutes. How many wires would this take??
01-24-2006 01:18 PM - edited 01-24-2006 01:18 PM
Message Edited by LV_Pro on 01-24-2006 02:22 PM
12-13-2007 02:56 AM
Could I ask you one question,please?
I've passed "the LabVIEW Fundamentals Exam".How could I see the list of people passed this one ?
12-13-2007 03:30 AM
12-13-2007 07:32 AM
Hey Putnam!!
Looks like you're as ancient as I am. I used to be a wiz at APL. Even have a PC version of it. Shame it died. I thought it was WAY better than C (at the time). OK... forget embedded, but wow, it could crunch numbers faster than anything at the time. ANd yes, you had to change the keyboard keys, 'cause it was "s-p-e-c-i-a-l". 😄
