03-31-2011 05:39 AM
Dear All,
I am using DSC module in LV8.6 for extract data form citadel database where i have runtime error
Here my PC name SBCPC and database vishnu.
What is missing in this so i have error.
--VP
05-11-2011 11:04 AM
Hi Vkumar,
I am using LabVIEW 2009 and i am getting the same error at my VI, do you found a solution?
Best Regards,
05-11-2011 03:00 PM
This error is when the VI dont found the Shared Variable because the name does not was correct.
In my particular case, i was using "Rename Historical Data.vi", I did change localhost at the path by the computer name and did work well.
Best Regards,
