CAN Frame Output Stream vi. make its work autonomous
Hello everyone,
I use CAN Frame Output Stream vi. I need to make ON and then OFF one digital signal. After that, It is necessary to turn ON-OFF more than fifty signals respectively. I write the CAN IDs as strings every time. And I do this sequentially in a flat sequence. Instead of rewriting these IDs each time, a single CAN Frame Output Stream is created where a frame message is sent to the relevant CAN ID when I want to turn ON the relevant signal. How can I convert it to a file?
In summary, what I want is:
To turn ON-OFF multiple signals with different CAN IDs and frames respectively with a single "CAN Frame Output Stream vi." with using flat sequence. I would appreciate it if you could explain it with a vi file.
Yours sincerely! Thanks in advance.
Message 1 of 1
(402 Views)
