Hi All,
I am using PXI controller "NI PXIE-8840 Quad Core" Provisioned the same to RT Linux and installed LAbVIEW RT 2019.
AS a POC I need to compile a C++ code to run in this RT Linux PXI.
The code is a Open DDS C++ code.
The PXI is a (Intel x64-based targets, 2017 software stack)
I had used http://www.ni.com/tutorial/14625/en/ tutorial to compile simple Helloworld stack using the Eclipse IDE.
The C++ code which I got is a kind of complete package.
What I understood is we need a command based compiler to compile the same and generate .SO file.
Need support for the same.
Thatnks,
Visuman
