Bytes at Port is zero after VISA Write
I am trying to connect mahr millitron with VISA Serial, but in my code, I get zero at "bytes at port". On the other hand, when I run "Simple Serial" example in Labview, firstly Labview runs E4 error later it works perfectly. Also, my code ran sometimes perfectly. Why is my code not working?
(1,724 Views)
Bytes at port is no good. Waits are no good.
Use the end termination character. Use serial init to set the end termination character, and you'll get a robust interface... Pretty sure the device sends termination characters, as you attach a \n to your message.
Why isn't your code working? Probably you have to use a longer wait... How long? Who knows... That's why waits are no good. You'll have to consider the longest wait, and add a margin. Even if the data is ready 99% of the time...
Why does the simple serial work, but not the first time? Probably because the first time there is no data (needs a longer wait) and the next iteration, you're reading the result of the first iteration.
(1,686 Views)
Duplicated post from here: https://forums.ni.com/t5/LabVIEW/Bytes-at-Port-is-zero-after-VISA-Write/td-p/4071000
Rolf Kalbermatter  My Blog
(1,676 Views)
