09-04-2013 03:15 PM
One place to look is the Agilent 34401 driver on your Instrument I/O>Instrument Driver palette. Look at the Initialize function. It sets the termination character for read and write.
09-04-2013 03:18 PM
Larryr11 wrote:Any chance of telling me how to correctly set up a "term char" element on the property node? Maybe I was not doing it correctly.
You really shouldn't be using a property node to set that up. Use the VISA Configure Serial Port VI instead. It has all of the settings needed for 99.999% of serial interfaces. By default, the termination character enabled and is set to 0xA (new line).
09-04-2013 03:42 PM
But the VISA Configure Serial Port does use a property node and you would need to modify the function to set VISA to automatically append a termination character for a write.
