Button permanently in keyboard focus
Hi all,
just as I thought I've seen it all, this happens.
I built a user interface with some setup information as well as a button to connect/disconnect.
After that the user can enter command in a line. The line is a system string control set up for single line and also update while typing to trigger a value change event.
Here's my problem: When I hit enter, the keyboard focuses on the Connect/Disconnect button and disconnects my application.
What I've tried:
  • reordering the tabbing order
  • adding a key down event
  • clicking on other buttons before writing in the string
The behavior I want is:
Enter text in string, press enter --> trigger string value change event
not focus on and press connect/disconnect button
ideally, keep focus on string, so the next command can be entered.
VI is attached it's written in 2012.0 f1.
I am grateful for all pointers and moral support in these trying times...
Remember Cunningham's Law
(2,499 Views)
Accepted by topic author PeterFoerster
Sounds like your button is bound to <Return>.  Right-click on the control, select Properties, go to the Key Navigation tab, and remove the binding.
(2,485 Views)
And also consider using a property node >>> FocusKeyBind to ...
When you get a "Command Key down" event and the character is NOT a Enter, set the FocusKeyBind for the command control.
When the key is an enter set the FocusKeyBind to the Boolean.
Ben
(2,479 Views)
Oh for crying out loud! It was right there...
Thank you for your quick response!
I removed the key binding and on enter, I set the KeyFocus to true.
(2,453 Views)
It happens to all of us.
See here for an example of when I was brain dead.
Ben
(2,438 Views)
