Building installer for application that depends on DAQmx
I came to the most painful part of application developing again: creating a build.
The .exe works fine but problem starts with generating an installer.
My program uses DAQmx for temperature and voltage acquisition.
I included these additional installers:
-Labview runtime
-NI-VISA runtime
-NI-DAQmx core runtime
AND THEN: when i click build, the program request additional media: Vision Builder AI.
I don't have that. And why would even need that because I don't use any vision components in my app.
Is there any workaround for this problem?
Please help.
Thank you.
Message 1 of 8
(2,817 Views)
What version of DAQmx and LV are you using? Maybe you should attach a MAX report for detailed information of available NI software components.
Can you also attach screenshots of the error dialog?
What is the OS? If 64bits: Is LV also 64bit?
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(2,805 Views)
LV 2012
DAQmx 9.5.5
OS Win7 32bit
Message 3 of 8
(2,798 Views)
You know that you can create a software screenshot by pressing ALT+PRINT keys for the currently active window? Then insert this in Paint and save it for posting 😄
What happens if you deselect the Vision Builder in the dialog and press OK?
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(2,795 Views)
Yes, I know, but the program is on another computer which is not connected to network so it was easier for me to take a picture with my phone 🙂
If I deselect Vision builder it says this:
"The selected media do not contain all the installers needed to build your installer. Select additional media."
If I click on the + sign to expand the selection, there is "NI System Components".
Message 5 of 8
(2,792 Views)
Again, please attach a MAX report. It seems to me that you have some/several evals installed.
Is this the only PC where you got these issues?
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(2,781 Views)
Here you go.
Message 7 of 8
(2,745 Views)
I see that you have LV 2013 installed as well. What happens if you use this version?
My question refers mainly to the fact that you have Vision Builder 2012 installed. I am wondering if LV 2012 somehow connects to this when building the installer and if 2013 possibly doesn't do that.
Norbert
Norbert
Expert: Geometry
Message 8 of 8
(2,739 Views)
