Build failed with filename has blank or has invalid characters error
This is an program that I have been maintaining for years. Nothing in this llb has changed in probably a decade, I can open the VI and I was able to successfully mass compile the llb containing it this morning.
But when I try to build the program I get this error:
The filename (C:\Program Files (x86)\National Instruments\LabVIEW 2025\instr.lib\rbllv201visa.llb\RBL SHORT On/Off.vi) entered is either blank or has invalid characters -- \ / : * ? < > | " <tab>
=== Engineer Ambiguously ===
Message 1 of 11
(1,020 Views)
Accepted by topic author RTSLVU
doesn't "RBL SHORT On/Off.vi" contain an invalid character?
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(1,000 Views)
Oh (expletive), you're right... I wonder why it took a decade for LabVIEW to notice?
Message 3 of 11
(990 Views)
I just dig through my backups and found a version of the llb from 2009 with the / in the VI name.
it's just strange that this is an issue all of the sudden.
Message 4 of 11
(965 Views)
LLBs never had as strong limitations about naming of the files inside. One reason is that they are single level, so the presence of any character in the name that may be used on any platform as path separator is not an issue. LabVIEW has always honored that and as you can see still seems to allow those names in your source LLB. The LLB manager should also allow it when transferring between LLBs but as soon as the VI has to be copied out of the LLB in any way, all those characters and a few more are forbidden since one of the supported platforms does not allow them. LabVIEW choses to disallow on all platforms any character that is used on any platform to avoid trouble when source code is transferred between platforms. That sort of naming conflicts is very difficult to resolve on the platform that disallows a particular character.
I can only suspect that the Build Tool changed something in the path logic that disallows this name now for maybe somewhat zealous reasons or that your memory is a bit vague about what exactly worked in the past. You are also not very specific about the exact type of build you are talking about. Source Distribution Builds may actually still work as the source and target is a LLB. Executable builds should have failed for a long time since LabVIEW does not create LLBs for executables anymore but instead creates a hidden hierarchy on disk of all the compiled files in an executable and then packs everything up into a disguised ZIP file that is then added to the executable stub. And the forward slash in a ZIP file is specifically a reserved character in file names since it is THE path separator inside a ZIP when the paths of file streams are stored in the internal directory structure.
So maybe the Executable Builder did in the past create LLBs inside that ZIP for source LLBs and for some reason changed to copy them to a directory instead, which naturally disallows these forbidden characters. Or it did so since 8.0 already and you remember something not quite right.
Considering that LLBs are declared legacy technology since about 6.0 (released in 2000, when Windows 3.1 support was discontinued, which was the only reason LLBs really were ever invented), it is not so surprising that things involving them are starting to break. It's very imaginable that someone decided recently that LLB support code has to be slashed completely from at least the runtime version of LabVIEW. And they would have of course changed the Application Builder accordingly to not use that anymore in a build of an executable, but that little detail may have gotten unmentioned in the release notes.
Rolf Kalbermatter  My Blog
Message 5 of 11
(923 Views)
This changed between 2023Q3 and 2025Q3. Same source code (containing a '/') now fails to build.
Message 6 of 11
(904 Views)
I remember running into a similar issue when LV pushed for abondoning LLBs and converting them to libs/folders (When i started working with LV in 8.2). Suddenly names were illegal and i ran into some unforseen issues ...
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 11
(847 Views)
TBH: I never understood the benefit of llb and lvlib files.
This llb came from the manufacturer and I have been dragging it along with me since LabVIEW 7 or 8
Message 8 of 11
(835 Views)
At least for LLBs, you don't seem to have worked in LabVIEW 3 and 4 on Windows. 😀
Windows 3.1 was simply a graphical shell above DOS. And DOS had a 8+3 filename limitation. Imagine your LabVIEW VIs having to be called MDConfM1.vi, MDConfM2.vi, MDConfM3.vi and so on, because you can't use more than 8 character for the filename. That's simply not really workable. So they had to invent something and their solution was a simple archive format, since trying to implement a whole ZIP infrastructure was at that time considered a major project in its own.
As to lvlibs, I suppose that was an easy byproduct of implementing lvclasses. There is an advantage to having a namespacing for a group of VIs and defining which VIs are public and which are private and inaccessible to an outside user. Yes you can go lvclass for that and get even more possibilities, but lvclass was back then something many LabVIEW users looked at rather suspiciously, since OOP was seen as that complex, overengineered and unnecessary dinosaur that made C for instance almost incomprehensible for an experienced C programmer.
Message 9 of 11
(815 Views)
Thanks, that makes sense. My first experience with LabVIEW was LabVIEW 5.1 on Windows 95.
Message 10 of 11
(800 Views)
