I'm building an application with TestStand 1.0.1 and LabView 6.0.2. After creating the TestStand engine and using the Build Application to build an Installer folder(including TS run-time & LV run-time engines, operator interface, etc.), I then installed the Installer to a target computer. The installation was successful. The problem comes when I ran the standalone executable, which is the operater interface. It can not open a sequence file, which has all the VI's I created to run my test. I noticed that the sequence file and library file that I created and transferred to the target computer were not recognized. The icons show a window flag. Usually, there's an icon with a check mark f
or the sequence file and an icon with folders for library file.
As I mentioned above, the TS and LV run-time engines are successfully installed. Why are the sequence file and library file not recognized? Any suggestions or advises. Thanks in advance.
