02-26-2007 02:46 AM
02-26-2007 03:12 AM - edited 02-26-2007 03:12 AM
Message Edited by daveTW on 02-26-2007 10:15 AM
02-26-2007 03:43 AM
02-26-2007 04:00 AM
I cannot see how it is a feature. If the input array is, I16 nothing whatsoever is gained by forcing an I64 format. You are losing resources all round. I suspect this one slipped through since unless the user is writing Hex this bug will not show up at all!
I am writing data to a file on cRIO and every byte is precious to me. Using a %4x positive numbers are 4 bytes long, but the negatives are now eating up 16 bytes every time. Of course I worked my way around using the 'spreadsheet to array function' and writing the text file as soon as I saw the problem. I could also figure out pronto that with integers LV only looks at I64.
02-26-2007 04:08 AM
02-26-2007 05:52 AM
02-26-2007 06:07 AM
