10-23-2011 06:01 AM
In this case you should apply the sensor info to the individual groups containg the data measured with this specific sensor.
10-23-2011 06:11 AM
Regarding the question whether this behavior is a bug, the answer is pretty simple: no.
Rationale: Consider you search for a file with a channel named 'speed' AND a unit of 'km/h'. There are two different ways to interpret this query:
A) There should be at least one channel named 'speed' AND one channel with the unit 'km/h', which results in a query like
file.group.channel.name = 'speed' AND file.group.channel.unit = 'km/h'
which will return results even in the case the channel named 'speed' has a unit of 'mph' only because there exists a different channel (maybe named 'speedlimits') with the unit 'km/h'.
B) There should be at least one channel named 'speed' with the same channel having a unit of 'km/h', which results in a query like
file.group.channel(name = 'speed' AND unit = 'km/h')
which will only retunr results if both conditions are met for the same channel.
This is the way DataFinder works.
10-23-2011 06:34 AM - edited 10-23-2011 06:38 AM
I agree with your last reply.
Maybe, there was a problem in communication with you.
As a second case, I expect some results by queries.
For examples, _prop.value1 is located in several groups and channel but I want to filter it by using datetime.
(Please see the my former attachment again)
The searching for the individual (_prop.value1 and datetime) was okay but none in their combinational queries.
labmaster.
10-23-2011 06:43 AM
Dear Stefan:
I have a LV 2009 version of developer suit. It includes datafinder in the package.
When I distribute my application after application builder, how to distribute the datafinder?
Do I have to purchase it separately?
Can I install only the datafinder from my package?
labmaster.
