It appears that the whole toolkit should be revisited for its error handling. I recently brought up a situation where an incoming error was being masked by an error generated by the toolkit.
Thank you very much for posting your work around! Would it be possible for you to post the code that demonstrates the bug? This would be very helpful for R&D. The more basic the code the better- that way R&D can more easily isolate the issue. Thanks!
Look at the ExceltoDatabaseCore.vi. basically it tries to insert a record, and if it already exists it will do an update instead (with an optional clause such as 'where mykey='identifying key' '
In that particular case, the first record counter will fail to decrease count.
