I found this bug and figured this is a good forum for both users and NI to
find out about it.
Place a tab control on a front panel and create a property node, select 'pages'
(which is an array of refs to each tab on the tab control). Index one of
the refs into a property node, it becomes 'page', select either 'page enabled
state' or 'page visible' from the available properties and connect the right
type of data in. In the development enviroment the code works fine to either
show/hide or enable/disable a tab, but once compiled into an exe the code
no longer works. Changing the state does nothing, all my tabs are available
all the time. I need to disable or hide one tab depending on permissions
avaiable.
NI - do you
have a fix for this?
Jared
