04-04-2013 01:33 PM
04-04-2013 02:08 PM
@DanyAllard wrote:
Hello Greg,
Finally I keep the Front and Block Diagram of a couple of VI and I got a successful build. But when I start the application, it report the main VI to be broken.
So what can be the next step to debug this issue?
It's hard to say. I'd try keeping block diagrams for more VIs until the application isn't broken after it builds.
04-04-2013 02:15 PM
04-04-2013 02:28 PM
@DanyAllard wrote:
Is it possible to see what cause the broken VI in a build application. Do you have at NI some sort of tools that can tell this info?
We don't have a great way to figure this out. One problem is that even if the top-level VI is broken, that might be caused by some VI being "really" broken deep in the hierarchy. Our only recourse is to debug LabVIEW, which can be a bit painstaking and is something only R&D can do. If you want to go down this path, we would need a copy of your application, and I'd recommend going through the normal support channels.
04-04-2013 02:45 PM - edited 04-04-2013 02:47 PM
04-04-2013 02:46 PM
@DanyAllard wrote:
Ok thank you Greg,
I will talk to my team about this. Is there a way to get prioritize for this issue. Currently this issue prevent me to deliver a new version to our client.
Again, I'd recommend going through support - they have the ability to prioritize things like this. I'm just a lowly developer...
04-04-2013 02:48 PM
04-04-2013 07:55 PM
Dany,
If you call support to open a service request, please PM me the service request number so I can follow up on it.
Jeff Peacock
Produce Support Engineer | LabVIEW R&D | National Instruments
04-04-2013 10:24 PM
I notice that I accidentally gave myself the title of produce support engineer. While it sounds like a fascinating job, that was intended to say Product Support Engineer ![]()
04-04-2013 11:23 PM
