Bug: Hidden Iteration Terminal prevents resizing For and While Loops via Ctrl-Alt-drag
Usually when resizing a for loop structure or while loop structure, the iteration terminal will move together with the lower left corner of the structure's border.
This is true when:
  • terminal is visible and resizing the structure by grabbing the border,
  • terminal is visible and resizing via Ctrl-drag or Ctrl-Alt-drag (and the start point for the drag operation is to the top right of the terminal),
  • terminal is not visible and resizing by grabbing the border.
The same is NOT true when:
  • terminal is not visible and resizing via Ctrl-drag or Ctrl-Alt-drag.
This means that reszing via Ctrl-Alt-drag is limited in range until the point when the border of the structure touches the (invisible) terminal.
Affected Version: LV 2021 SP1
Steps to reproduce:
  1. Place for loop or while loop structure.
  2. Hide iteration terminal.
  3. Try to shrink the structure by Ctrl-Alt-clicking into the center of the structure and dragging towards the top-right.
Expected behaviour:
Structure shrinks unhindered as long as there are no other objects interfering with its border.
Actual behaviour:
The structures border is blocked by the invisible terminal and can't be resized by more than a few pixels.
Loop after failed resize attempt with iteration terminal re-enabled:
This same behaviour can be observed with for loops and while loops.
Event structures with a hidden event data node do not seem to be affected by this bug.
Message 1 of 11
(4,190 Views)
I think you have auto-grow turned on. Turn it off and try again. It works for me as expected when auto-grow is not enabled.
Certified LabVIEW Architect
Message 2 of 11
(4,184 Views)
But I agree that it is not what I expect. If the "Iteration terminal" setting would have been on the "Visible Items" sub-menu, then I could maybe accept that the terminal simply is not visible but still there, but with the menu-selection as it is now, I would expect the iteration terminal to be removed entirely and thus not affect resizing regardless of auto-grow settings.
Message 3 of 11
(4,180 Views)
That's a good one.  I guess I never noticed because the first thing I do is turn off auto-grow.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(4,145 Views)
The bug is even weirder than that.
I was about to disagree with your statement because I did not see any change in behaviour after disabling "Auto Grow" on an existing loop.
Turns out, I have the option "Place structures with Auto Grow enabled" checked in the options menu.
If i disable this option and place a new structure, the problem almost goes away.
Why almost?
Because after shrinking the loop with Ctrl-Alt-drag and subsequently re-enabling the iteration terminal, it does not show up at all:
Only after resizing the loop by a few more pixels via grabbing at the border it becomes visible again.
Again, this bug is not present when resiszing by grabbing the border of the loop.
Message 5 of 11
(4,104 Views)
Why almost?
Thanks for the deep dive into the issue!
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(4,089 Views)
You can make the i-terminal move beyond the loop border even when it is visible this way. In fact, now there is a way to get it back without enlarging the loop and searching for the terminal. Now you only need to disable and then enable the terminal and resize the loop by a pixel. It would be better it resizing was not needed and the terminal was placed within the loop bounds directly when enabling the terminal though.
But I have always wondered why it is allowed to move stuff outside of the loop borders but still be in the loop, hidden beneath the outer diagram. I guess that was one of the things that auto-grow tried to solve.
Message 7 of 11
(4,086 Views)
Message 8 of 11
(4,082 Views)
I've posted this before, but nobody seemed to care...
Note that showing or hiding the iteration terminal does not mark a VI as changed.
Steps to reproduce:
1) Using LV20 (haven't tried a more recent LV)
2) Create or open a VI with a loop.
3) Save it.
4) Show or hide the iteration terminal.
5) Notice there's no * to indicate that the VI has changed.
Save all won't save this VI. Next time the VI is loaded, the terminal is back to it's original state.
Message 9 of 11
(4,069 Views)
Steps to reproduce:
3) Save it.
That sounds like a different problem than the rest of this thread.
Currently using LabVIEW 2022
Message 10 of 11
(4,031 Views)
