03-01-2017 12:33 AM
I thought I'd report this bug, only to discover it was reported almost six years ago (in LV2010). CAR #298993 was raised, but the bug is still present in the LV2017 beta. Any time frame on a fix?
03-01-2017 06:26 AM
As a note, it works if you select several items and drag-copy them. It's related to grouped copy.
/Y
03-01-2017 07:08 PM
I'm not sure if we're talking about the same issue. I've attached a VI with a bound control, grouped with some text (the "RMS" subscript). If I ctrl+click+drag the grouped item, then check the binding properties of the new numeric indicator, it's now unbound (and the little binding LED indicator disappears).
Similarly if I ctrl+click+drag the grouped item (or simply copy/paste it), deselect the group, then select the group and click+drag to move it around, the binding LED indicator also disappears.
03-03-2017 08:16 AM
Michael,
I was able to reproduce this from the VI you attached. I will take this to some of our product specialists to see if I can provide any feedback here.
03-03-2017 08:52 AM
Michael,
Also as a side note, please use the dedicated Beta forums to post your questions related to this version. All bug reports are being tracked there. You can find out more about this here:
http://forums.ni.com/t5/LabVIEW/Announcing-the-LabVIEW-2017-Beta-Program/td-p/3567123
03-03-2017 12:20 PM
@Mada_17 wrote:
Michael,
Besides beta bugs being tracked there, isn't it not allowable to even be discussing the beta outside the beta forums?
