Bronkhorst Sensors
hey, I want to set/get data to Bronkhorst sensors, which are two flow meter/controller and one press meter/controller. it is possible via Modbus according to their datasheets, however I have no idea about how to implement it .like what is the name of registers and which kind of command I should send to the sensor?I did download the Modbus lib. from NI website, and already built the communication with another modbus device. so, is there anybody here has experiences with this Bronkhorst sensors? any suggestions or advices are very appreciated.
cheers
Message 1 of 12
(5,759 Views)
Do you have any manual/command set(for modbus) for these sensors or try getting them in their website for that model. which will give you a clear idea of how to get/set data to these sensors.  jus post them so that forum can look and answer to your queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 2 of 12
(5,754 Views)
thanks for replying, I already sent the company questions of asking for the manual, however havent got any information yet.
here attached the datasheet of the sensor. there's no information about how to set the address of registers
Message 3 of 12
(5,739 Views)
the datasheet
hope somebody here has experiences with it .
cheers
Message 4 of 12
(5,738 Views)
Coud you send me an email. Just add .nl after the user name.
I have a specification document for the MODBUS-RTU protocol for Bronkhorst products, I just don't want to post docs that are not on the website.
André (CLA, CLED)
Message 5 of 12
(5,723 Views)
many thanks for replying
but now i have a silly question. on the meter/controller there's only a subD connector(9pin), but on the other end, there suppose to be a RJ45 connector. I never saw this kind of cable before~~ do I need to make one?
cheers!
Message 6 of 12
(5,694 Views)
No, those are standard cables. You can buy them from a lot of places, e.g. NI has them for sale (not the cheapest of options).
There often used with serial cards that have more than 2 ports.
André (CLA, CLED)
Message 7 of 12
(5,687 Views)
okey, thanks a lot.I will try to get it, but btw, what's the name of this kind of cable?or i just say, a cable:one end is RJ45 , another end is SubD 9pin?
Message 8 of 12
(5,639 Views)
http://www.massflow-online.com/shop/index.php?main_page=product_info&products_id=17 is one of the hits when searching for "RJ45 to DB9" on Google.
André (CLA, CLED)
Message 9 of 12
(5,634 Views)
Accepted by topic author echomice
Thanks very much and this is lots of help!
Message 10 of 12
(5,610 Views)
