Broken Wire but Runnable. Should I be concerned?
How concerned should I be if I have a few VIs where the run arrow is not broken, but a wire regularly shows up as broken?
If I replace the wire, it's non-broken again.  But when I come back to this VI later (perhaps after recompile), the wire's broken again -- even though all code runs.  I've seen this in a few places -- and yes, the VI on the right is a malleable VI.
LV 23, Q1, 64-bit.
(1,247 Views)
I've seen this a few times with malleable VIs in LV 2020, I thought it had been fixed.
Most times, the Vi is fine and the display is wrong, all you need is a recompile.
Epictetus
Antoine Chalons
(1,193 Views)
I'd be worried about that unbundle though 😊.
.vims cause all combinations, broken wires\running VI, good wires\broken VI, broken wires\broken VI...
(1,142 Views)
That's the coolest unbundle I've ever seen.  How do you do that?
(1,110 Views)
I assumed the image was obfuscated by the user (e.g. in paint).
(1,101 Views)
