You can use a VI Server Property node to bring a VI's front panel to the front.
1. Drop a Property Node from the Application Control sub-palette on your diagram.
2. Right-click on it to Select Class >> VI Server >> VI
3. Now select the Front Panel Window >> Is Frontmost property.
4. Change the property to Write (right click to bring up the pop-up)
5. Wire a TRUE to bring the VI's front panel to the front.
You can use the property node any time you reach a point in your code that requires user input on that panel.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
