For a document that will walk you through the
configuration of your server using Lookout Protocol Drivers (LPD) please
browse
to:
http://digital.ni.com/public.nsf/websearch/00cbb8f7b2f66e02862568c10056eccf
Once you've setup the LPD, use BridgeVIEW's Tag Configuration Editor to create
Tags from the LPD.
Khalid
"Vlad Dragomir" wrote:
I try to communicate with a Siemens Simatic S5 115 U PLC 943. In Lookout,
the communications is made with a AS511 driver (Create->Driver->S_AS511)
using serial port COM2 (or any other serial port available). In the National
Instruments, catalogue for year 2000, page 182, it is written that BridgeView
has all the Lookout Protocol Drivers (Table. 2) How can I communicate with
the Simatic in BridgeVie
w using the serial port?
Vlad Dragomir
