Boolean swicthes to control what is displayed on the front panel
I am trying to use a Boolean switch to expand what is being displayed on the front panel and to reduce what is being displayed on the front panel. Similar to the LabVIEW screen when it first comes up and have a small dialog and large dialog boolean switch
(2,890 Views)
Find attached example ... I think it's not the optimum but you can have an idea how to do it. (note: it's for LV6 ... if you have 6.1, use events to find out when the switch changed)
Hope this helps
(2,890 Views)
Mont,
Try to use the property node (visible option) for all the controls and indicators you want to hide and/or display and put that in a case statement.....so that if the boolean switch it TRUE/FALSE whatever you want is either visible or invisible.
I have attached an example program....
Good Luck.
-Pari
(2,890 Views)
I created a simple example. I hope you find it useful.
Aguila.
(2,890 Views)
