Boolean Crossing PtByPt VI
Hi, I am new to LabVIEW and have try to use the Boolean Crossing PtByPt Vi as attached but it does not cross into the stage when I trigger the input. Can you advise? Thank you.
(3,157 Views)
Looks like you are trying to capture the event of a boolean changing. Lucky for you there is a structure to help called an event structure.
See what happens when you make a vi like this:
(3,117 Views)
Thanks, Steven
(3,093 Views)
Accepted by topic author glendale
You didn't attach a VI, you attached an image of the VI.
The crossing probably is detected, but your VI runs so fast (without a wait) that you won't be able to tell. The crossing is only true for one iteration, and that will last for <1 ms.
Run the VI with execution highlighting on. Or put a wait in the VI. Or make the loop stop if the condition it true.
Once you get the problem, step up to the suggested event driven solution.
(3,026 Views)
Thanks, Wiebe
Yes, I get to know where is my problem here, thanks for sharing.
TS
(3,005 Views)
