Bold axes on xy-diagram
is there any possibility to show some axes-lines of a xy-diagram as bold lines?
Of course I can show them as coulored lines but when I print the diagram they cannot be differenced from the other lines.
Thanks for your help!
Jan-Hendrik
(2,992 Views)
Yes;If you right-click on a trace in the plot legend window, one of the options you can set is the line "weight". This property is also available programmatically.Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,992 Views)
Hi Mike,
thanks for your answer but its not what I wanted to to.
I want the right y-axes-lines (the red lines in the example) to be bold and not the plot.
Hope my English is not too bad.
Jan-Hendrik
(2,992 Views)
Hi Jan-Hendrik,
I browsed through the properties of graph, but could not find a way to change the marker grid width either.
Time ago I had the same need, what I did was to add flat plots of constant value (lines) to the chart and customize their appearance as plots.
If you want to place these lines progammatically based on the position of your markers, you should use the property Y-Scale.MarkerValues that returns an array of matker values of the selected scale; use these values to build arrays to be displayed on your chart.
Hope I've been clear enough, let me know,
Alberto
(2,992 Views)
Hi Alberto,
thanks for your helpfull answer. I'll try that.
Jan-Hendrik
(2,992 Views)
