Blowfish Encryption zLibInflate.vi Error
Using LabVIEW 2108 32-bit:
I downloaded and installed the LabVIEW Blowfish Encryption.llb  It includes a zlib.dll that I'm not sure what to do with...
I moved both llb and dll to LabVIEW 2018/user.lib and restarted LabVIEW.  All VIs are fine except ZLibInflate.vi and ZLibDeflate.vi
Errors are:  Code Interface Node: LabVIEW subroutine link error and Code Interface Node: Object code not loaded.
Details:  The external subroutine could not be found
Any help is greatly appreciated.
(2,114 Views)
Accepted by topic author SJT
The blowfish doesn't seem to use the in\deflate. Those functions don't sue the dll, but a CIN. CINs are obsolete (have been for years). So, I'd simply delete the VIs and the DLL.
LabVIEW Blowfish Encryption.zip
(2,063 Views)
Thanks.  I ended up loading the original library and it worked.  The newer one does use Inflate/deflate so blowfish won't run due to the above problem.  I'm not sure why it got updated to a non-working library but it did.
(2,050 Views)
