04-18-2007 07:54 AM - edited 04-18-2007 07:54 AM
Message Edited by ENSTB_Vivien on 04-18-2007 07:55 AM
04-18-2007 08:06 AM
04-18-2007 08:50 AM
I think your VI is corrupted also.
It opened nearly 15 instances of LV 7.1 when I downloaded to the desktop & tried to open it... !
Seems to be a very strabge behaviour !
See the attached screenshot.
04-18-2007 08:56 AM
Partha,
That's just the standard message you get when the VI has no block diagram and doesn't indicate the VI is corrupt.
04-18-2007 09:03 AM
Sir Dennis,
If you look at the bottom of the attached screenshot, you can see 5 instances of LV being opened in the Windows Taskbar.
But, I had closed LV after reading this post specifically to see the message it is going to show me as you had mentioned in your post.
So, when I downloaded & opened this VI, LV started up upto 15-16 instances & after seeing & closing the msg boxes again & again, I thought of posting it in the forum, thinking that I'd get a quick reply since you re online.
Thank you very much, Sir.
Maybe a bizzare condition with my PC, like I ve said in this post.
http://forums.ni.com/ni/board/message?board.id=170&message.id=242373
04-18-2007 09:15 AM
I don't see that behavior at all.
p.s. I'm using a much slower pc and with half the RAM for 7.1.
